Buying a soldering iron
platinum95
Post by platinum95 » Thu Jan 19, 2012 6:09 pm
Ok so I am looking to buy a soldering station for general hobby circuits etc. I found that weller are just too expensive for me, but I am sure their products are top-notch. I was looking more into the budget side of things, namely either:
http://ie.farnell.com/tenma/21-10115-eu ... dp/2062627
Or:
http://ie.farnell.com/duratool/1498366- ... dp/1737236
Or:
http://ie.farnell.com/tenma/at60d-eu/so ... dp/2075392
Now I know that these soldering stations will not be of a very high quality, but to be honest that doesn't bother me, as it's a hobby that I have, and I'm still in my teens so when I am older I can buy an actual good one.
Can someone point me in the direction of a soldering station that's around the price of those 3, under 100 euro, 130 dollars or 84 pounds.
Thanks in advance.
pounder35
Re: Buying a soldering iron
Post by pounder35 » Thu Jan 19, 2012 8:02 pm
It depends on the wattage (heat) you need. Looks like great equipment but what are you using it for? I repaired 35mm camera equipment for over 20 years with an Antek. No fancy digital digital display or temp. control. It's what you're using it for and learning how to use it. As with anything use the right tool for the job.
pounder35
platinum95
Post by platinum95 » Thu Jan 19, 2012 9:41 pm
I need something thatll be there when I need it, I intend to do a bit of SMD work, but more padboard kind of stuff. I'd prefer to have a temperature controlled one because I find a lot my plastic switches and stuff tend to melt before I can solder wires onto them when using my 25 watt iron, and also because some work is pretty temperature specific.
SamRodgers
Post by SamRodgers » Sat Feb 04, 2012 9:04 pm
From age 10, I used a cheap 25W iron. If you can solder with that, you can solder with anything. Buy an iron with a choice of tips. I prefer a 1.2mm conical tip for most jobs because I can rotate it back and forth. The rotating tip scrapes away the oxide to maintain good thermal contact while I apply solder to the wire. Soldering is a skill that improves with practice.
It was many years before I could afford a Weller. I use a 430°C tip, which most people would think too hot. But I'm extremely quick.
I also (still) use 60/40 tin-lead solder unless the job specifically requires lead-free for whatever reason. Contrary to popular belief, the lead doesn't vaporise at 430°C (or a long way above) so there's no danger of poisoning as long as you keep the solder (and your fingers) away from your mouth. Always wash your hands afterwards.
Agent24
Post by Agent24 » Sun Mar 04, 2012 12:35 am
platinum95 wrote:Now I know that these soldering stations will not be of a very high quality, but to be honest that doesn't bother me, as it's a hobby that I have, and I'm still in my teens so when I am older I can buy an actual good one.
Any of the three you posted will do fine for general hobby work. The Tenma AT60D (and in fact, the other Tenma too) might be the best one as it looks like the iron is compatible with Hakko 936 and there are many different types of tips available in the 900M series, which will help if you want to get into SMD stuff later.
Duratool is a pretty nice brand though. The OEM is ZhongDi and spares can be found under all sorts of names.
SamRodgers wrote:From age 10, I used a cheap 25W iron. If you can solder with that, you can solder with anything. Buy an iron with a choice of tips. I prefer a 1.2mm conical tip for most jobs because I can rotate it back and forth. The rotating tip scrapes away the oxide to maintain good thermal contact while I apply solder to the wire. Soldering is a skill that improves with practice.
As did I. A Scope MH-25 to be exact. Still got it actually ;) Not so sure about the bit where you rotate the tip though - the flux by itself always worked good enough for me. As I understand it, scraping the tip against the joint is just a good way to ruin the plating quicker.
