Looking for 0.8mm (1/32") SRBP PC Board
MarkF
Post by MarkF » Wed Oct 03, 2012 7:34 am
Hello,
I'm on the hunt for 0.8mm thick single sided PCB - the SRBP (FR2) type, not FR4 fibreglass. The reason is that the model railway association (www.2mm.org.uk) to which I belong uses it to make sleepers to which the rail can be soldered. The tooling we have to make the sleepers needs 0.8mm thick material. We cannot use 0.8mm FR4 as the fibreglass content will ruin the cutting edges of the guillotine. SRBP board cuts very accurately and quickly using the tools that have been developed.
1.6mm thick material is still readily available but that's too thick and would need a lot of machining to make it thinner if we were to use it.
If anyone has any offcuts of 0.8mm board or knows of any suppliers, I'd be very grateful.
thanks
Mark
SamRodgers
Re: Looking for 0.8mm (1/32") SRBP PC Board
Post by SamRodgers » Sun Oct 14, 2012 2:15 pm
http://www.rapidonline.com/Tools-Equipm ... oard-32634
They state that this board is "approx 1mm thick".
Best I can do without spending hours on searching.
davek
Post by davek » Thu Feb 28, 2013 7:14 pm
Hi Mark,
bit of an old post and not sure if you've sorted your problem. but try presspahn.com i buy their FR4 sheets to make turret boards for hand wired guitar amps, i seem to remember they also stock SRBP material as well.
dave
