Help with a switching issue
Posted: Fri Mar 09, 2012 8:24 pm
by DaveClark
Hi all,
I wonder could you help with an question I have?
I have an extractor fan, plugged into a 13A socket.
The 13A socket is controlled via a digital thermostat. (similar to this one)
When the temp gets to high, the fan runs.
When the temp drops below a given point, the motor stops. All this works great.
However, I would like to change the operation so that when the thermostat circuit cuts power to the fan, instead of stopping, the fan idles.
In order to make the fan idle, I have a variac available.
Any ideas on how this could be connected? Would I need some kind of relay controlled switching circuit?
Thank you for any advice you can offer.
Dave
Re: Help with a switching issue
Posted: Fri Mar 16, 2012 11:50 pm
by Biffo
How about something like this which as a trickle fan control?
http://www.ebay.co.uk/itm/PRE-WIRED-HYD ... 27c3952b48
