Please, how can I use 240v to trigger a 12v water pump
Posted: Wed Oct 03, 2012 1:09 am
I would be grateful for a little advice, please.
I am rigging up a rainwater catchment system to supply a washing machine. I need (due to lack of pressure) to pump water to the washing machine (using a 12v submersible pump). So that the pump is only activated, when needed (to supply the washing machine), I have an idea. Through the normal operation of the machine a solenoid is activated to open the water supply valve and another 'signal' closes the valve once the water level is reached. I want to use these electronic signals (to the washing machine water inlet valve) to switch the pump on and off. How would I do this, what components would you suggest ? The pump will be supplied by a lead/acid battery with its own charging circuit (which will be eventually be connected to a solar cell arrangement.)
All suggestions, ideas etc would be very much appreciated.
Thank you
Thank you
