Voltage limitation
Posted: Sun Feb 08, 2009 11:18 pm
Hi all,
I am currently building a car(how far away from building electronics can you get lol) which uses a motorbike engine.
I have had to fit an electric water pump due to the oil system I have to use so have purchased a digital controller the same as this
http://www.daviescraig.com.au/main/display.asp?pid=56
I need to reduce the voltage to the controller as it keeps going into test mode as the generator on the engine is producing up to 15.1 volts which is within the specs of the engine manufacturer.
I must admit I have not measured the amps yet but can do quite easily if needed.
How or what do I need to do to limit the voltage to the controller.I have limited electronics experience but have built a Megajolt ECU for my old car from a kit of parts so can solder etc but I dont know what I need to get/make to hopefully resolve this problem.
Many thanks
J
Many thanks
J
