Basic Voltage drop question using LED
Posted: Wed Jul 10, 2013 7:55 pm
Hi I am just starting out so please bear with me as I realise this is probably a very basic problem I have. I am currently learning about Voltage and have made a simple circuits with a 6volt battery, resistor and LED.
• The voltage drop across the battery is 6volts.
• Across the resistor is 4.5v and across the Led 1.5 v which all adds to 6volts. This makes perfect sense to me.
• If I take out the LED the drop across the resistor is 6v and the battery 6v – again it makes sense.
• But If I just use the LED the drop across the battery is just over 2 v and across the LED is just over 2v.
• And If I try the experiment in software such as “Circuit Wizard” the voltage drops over both remains at 6v – can someone explain what is happening – I thought it should always be 6v?
thanks for your reply.
