Mini-DIN Panel Adapter
Posted: Sat Sep 07, 2013 3:39 pm
Hello,
I'm looking for a mini-DIN panel adapter but I don't know if such an item exists.
I have and in-car intercom system and the connectors for each headset are 6-pin mini-DIN. The plugs on the headset leads are male and the corresponding sockets on the unit are female. Rather than plugging the headsets directly into the unit, I want a pair of intermediate panel sockets that I can mount in the dashboard. I would prefer not to have to cut and solder cables and connectors, so my ideal solution is to find a panel adapter that has a male plug on the rear and a female socket on the front. I could then connect the unit to the rear of the adapter and plug the headsets into the front.
Does anyone know where I can get such an item?
Thank you,
Paul
Thank you,
Paul
