Need help with CMOS 7555 abstable output @ 800 KHz please
Posted: Sun Feb 22, 2015 5:44 pm
Hello
I'm new to the forum and I was looking for some help regarding an astable output I am trying to obtain from CMOS 7555 timer if possible please. I'm simulating a basic Modified Sine Wave generator for a high frequency wave using Circuit Wizard. I've created the circuit and it seems to work ok in simulations however the output from the 7555 is not a square wave but rather triangular in the simulation. The IC is rated for 1 MHz as I understand it so It should be ok and is this just a result of the slew rate of the timer? The J-k Flip-flops still seem to recognise the negative edge without a problem in the simulation I am just wondering if this is to be expected and will still function as an astable output in reality. I have attached the circuit diagram for the 7555 component and also the simulation output, red wave is the 7555 output and the blue wave is the produced modified sine wave. I would appreciate any help anyone could provide please.
Values
C1 - 0.00001 µF
R1 - 15 KΩ
R2 - 82 KΩ
Frequency - 806145.2514 Hz.
Duty Cycle - 54.2 %
Values
C1 - 0.00001 µF
R1 - 15 KΩ
R2 - 82 KΩ
Duty Cycle - 54.2 %
