Help me identify this component?
Posted: Thu Jan 05, 2017 3:28 pm
Can anyone help me ID this component, please? and if possible where I can buy 1 (or 10!)
The item, as best that I can describe, is a switch actuator or housing for a micro switch.
The actuator is fastened to a desk and inside the desk, the micro switch sits inside the actuator so when the actuator is pressed, it presses the microswitch.
The key thing here is that I can remove the micro switch, complete with the associated equipment and leave the actuator in place, bolted to the desk.
I obviously could just fit a normal SPST switch to the desk but then I would have to unsolder the wires to the switch, or fit spade connectors and pull them off when I wanted to remove the equipment.
