Parallel Voltage Regulators
Posted: Thu Dec 31, 2009 10:39 am
I am having a bit of a problem with a design I am working on and I would appreciate some advice. I need to produce a circuit that will accept an input voltage of 12 - 14V and will output 5 volts at a continues load of 0.9A. My initial design was to use a single L78S05CV as that is rated up to 2A. However, when I did the maths, I realised that the heat sink that I would need was impractical for the box it has to fit in. After hitting Google I found an article that said that I could put 2 of these regulators in parallel as long as I managed the current and it provided the following circuit, using 2 regulators, some diodes and a some caps which it claimed would do the job. The circuit shows 2 x 12V regulators, but I cannot see why it could not be implemented with 3 x 5V regulators?
I do have room on my circuitboard for 3 regulators each with a small heat sink (I have a max height limit of 10MM) which should be OK as I think each reg would be producing less than 3W which should not be too difficult to dissipate using a 24C/W heat sink.
If I understand the circuit correctly, the voltage drop across D1 and D2 is offset by D so the output voltage is still 5V?
Any comments, advice, alternative solutions would be much appreciated. To be a viable solution it really needs to cost no more than £3.00 to implement and it must be reliable.
Regards
Tim
Regards
Tim
