I would rather not ship to outside the UK, and would expect the recipient(s) to at least cover my postage costs.
Thanks for reading
INFO
Some of the bits are still in original packaging, or never been used (indicated in brackets), but most of them I reclaimed from a bunch of old (fully working) computer terminals, so I assume they work, but I don't know for sure:
-- Eproms - contain data & need erasing
2716 - 16K eprom x5
2532 - 32K eprom x5
2732 - 32K eprom x1 (in original packaging)
2764 - 64K eprom x20
27128 - 128K eprom x16
27256 - 256K eprom
27512 - 512K eprom
xicor x2804 - latched eprom
TMM 24128AP - 128K eprom
-- RAM
HM6264LP - cmos static ram x14
HM6116LP - cmos static ram x1
HY6264 - cmos sram x2
CXK5864 - cmos sram x4
LC3664 - cmos sram x9
-- CPUs
MC68A09 - 8bit CPU x2
68B09 - 8bit CPU x2
Z0868112 - Z8 romless
Z80ACPU - 8bit CPU x3
Z80ADART - Dual Asynchronous Receiver/Transmitter x4
Z80CTC - Counter/Timer Controller x2
Z80PIO - Parallel Input/Output controller
Z80SIO/2 - Serial Input/Output controller
D8279c - Programmable keyboard-display IC (in original packaging)
CDP6402CE - cmos UART (in original packaging)
-- Logic
SN74LS75N - 4bit bistable x4
TL497ACN - switching voltage regulator
74LS20 - 4input nand gates
74C32N - 2input or gates
74LS244 - Octal 3-STATE Buffer/Line Driver/Line Receiver
7408 - 2input and gates
MC74HC4060N - 14stage binary counter (in original packaging)
SN74HC4040N - 12bit binary counter (in original packaging) x2
MAX232CPE - RS232 transmitter/reciever (in original packaging)
M74HC4024 - 7stage binary counter (in original packaging)
SN74HC138N - 3line to 8line decoder (in original packaging)
-- Other
28pin zif IC socket
24pin zif IC socket
24pin ic socket (Never been used)
28pin ic socket x5 (Never been used)
BC558 - transistor x4 (Never been used)
ZTX750 - transistor x5 (Never been used)
2457.6 - crystal (Never been used)
