[quote=As you say, I think a capacitor should work to block constant light signals from the circuit and only allow pulses through. Try a small (0.01uF?) capacitor in series with the base connection of Q1. You might need a pull down resistor (100k?) from the Q1 side of the new capacitor to ground (negative side of battery).[/quote]
Thank you for your comments. I have tried a few small capacitors as suggested, this blocks ambient
& the pulsed IR. I have tried 0.01, 0.1 & uF values but when I do this there is no voltage on pin 2. I have tried removing C1, adjusting P1 and reducing R1. Tried the pull down resistor but as I understand it..thats to make sure theres no voltage on pin 2 when the input from the transistor is off?. I've checked the base side of Q1 before the capacitor and there's around 8Volts there (under lighted conditions) but nothing at the Q1 side of the capacitor.
so it seems the ac frequency is not 'strong' enough to bridge the capacitor
Is that because the frequency i'm using is low (125hz)? does this mean I need a much smaller capacitor.? am I making sense..I am at the limit of my understanding of electronics.
I think I really need a circuit design with a wide bandpass filter with lower and upper cut off levels of 80 and 700hz. Would I be better incorporating an op amp based bandpass filter in place of Q1?
piscesguy
