Rope Light Power Supply
Posted: Thu Sep 25, 2008 9:02 am
I'm trying to adjust the length of cable between some led rope lights and their power supply.
(To be specific, I'm trying to shorten the length of cable - if that makes any differnce?)
The motivation behind this project is to 'pet proof' the lights, so ideally I want/need to conceal as much of the cable as possible in conduit and any circuitry that may be required in a box of some description.
Currently there is:
A 3 pin plug.
A short length of cable.
A black box.
Some more cable - this bit's too long!
The rope lights.
The black box has Decorative Light Controller written on it and I also found this information which I'm hoping will be useful.
230-240v 50Hz 2x0.4A
Other than that it has various manufacturers logo's stamped in the plastic one of which I think is Quasar - but whether it's the same people you recommend buying 'kits' from or not I'm not sure.
I'm pretty much a newbie to electronics at component level though I am competent with general household electronics (lighting rings etc).
I'm looking for advice on how best to tackle this job.
I guess the easiest is simply to cut the wire, remove a section and re-join it with terminal block(s) - but that may be hard to conceal in conduit.
I was thinking I might remove the black box completely and replace it with something else?
If this was the case I don't really care whether the lights flash or not once the project is done.
I just want to be able to turn them on and off (and maybe dim them - but that is optional).
Anyone know where to start with this?
Thanks in advance...
Chris.
Currently there is:
A 3 pin plug.
A black box.
The rope lights.
Chris.
