GPS, Sensors & Microcontroller
20 years ago I completed a degree in electronic engineering, however I was seduced towards software engineering. After a long break I've dug out my soldering iron and started a hobby project. As I'm very out of date I would really appreciate any advice or suggestions.
My project is to build a telemetry data logger for a Go-Kart. I've been given a GPS (GPS Module with onboard Antenna GPS-622R) and I would like to use a microcontroller to take position data from the GPS module and store it to memory. In addition, I would like to capture 3 channels of analogue data - pitch, roll and throttle. Finally, I would like to transfer the logged data from the data logger to a PC via a USB cable.
I'd appreciate any comments on the above and in particular on the following questions:
1. any recommendations on the selection of the micro-controller - I've been looking at the PIC16F627 as I can pick up a relatively cheap programming kit from Maplin.
2. any ideas on sensors to measure pitch and roll?
3. any suggested reading on the USB integration with a PC? This is the real unknown area for me - I've integrated sensors and microcrontrollers before (albeit 20 years ago) but I've never worked with USB.
Any thoughts on the above would be very gratefully received.
Many thanks.
James.
Many thanks.
James.
- Site Admin
- Contact:
Re: GPS, Sensors & Microcontroller
A couple of quick answers:
1: Go for one of the 18F series of PIC micros, or the 30F / 33F if you need more power. They can be programmed efficiently in C and have a good range of peripherals built in.
3: Leading on from this, PIC micros with USB are available complete with free USB stack firmware and drivers from Microchip - see www.microchip.com/usb. Again the 18F series have USB versions (I've used the 18F2455 as a USB - serial converter, more powerful ones are available), I think there are 30F / 33F versions too. You need to start with the USB stack and add the rest of your code to it - trying to integrate the stack into an existing project is a bit of a nightmare.
Not sure about 2, some sort of gyro I would imagine, but there might be simpler / cheaper options.
Thanks Simon for the reply and the pointer on the PIC and the USB integration - I'm looking into that now.
On the subject of the tilt sensor, I've found a couple of electronic gyros - typically they're priced around £40 so quite an expensive component. I don't require a high sampling frequency so such devices could be overkill. I'm considering mounting a series of mercury tilt switches at different angles, however that seems like a very crude solution and I suspect it might not be very reliable.
James.
James.
- Site Admin
- Contact:
There must be something quite common now since a lot of smart phones have motion sensors in them. Mind you I suppose they are using them in large enough quantities to get the price down. Thinking about it, I think it's accelerometers that are used in phones - might be worth looking into them. Tilt switches could work depending on how many angles you need to sense.
