LCD Driver help pls???
Hi all.
Im about to purchase this high powered LED shown here, the data sheet is here aswel.
http://uk.farnell.com/ledengin/lz1-00db ... dp/1678946
I carnt find the correct driver to run it from a 12v power adapter i will be using.
Also do i need a heatsink for this LED as you can see its quite expensive so i want to make sure its done correctly.
any help much appreciated.
I did speak with a tech over live chat an he recomended this driver but im not sure whether hes right.
http://uk.farnell.com/xp-power/ldu2430s ... dp/1738296
hopfully ill get to the bottom of this project with a little help
Peter.
Peter.
Re: LCD Driver help pls???
Don't know if this web site could help you but have a look. http://www.luxeonstar.com/ I would definity use the largest heat sink I could find.
