Led laser line pointer
Jwm0270
Post by Jwm0270 » Thu Aug 29, 2013 2:01 pm
Hi ,, does anyone know if it is possible to buy;
I was looking for a laser line pointer. Like what is built into a Black and Decker laser level for DIY. Ideally can be seen in daylight could I get the components and what would I need to power it. I have a small project which needs to point lines on the ground and up walls with a wide angle 180deg coverage, probably need two pointers.
Don't need all the Black and Decker housing just the pointers and power source.
Have not a clue to the power or spec of these led pointers.
Thanks,
Stephen Spencer
Re: Led laser line pointer
Post by Stephen Spencer » Sun Sep 01, 2013 9:43 pm
Jwm0270 wrote:Hi ,, does anyone know if it is possible to buy;
Thanks,
Stephen Spencer
Post by Stephen Spencer » Sun Sep 01, 2013 10:09 pm
LASERS: ARE A VERY "DANGEROUS" SUBJECT, To: The Untrained, Please Do-Not, Expect anything, Better From: "Cheap-Crap. From, CHINA, (If You want : (100-400 mW. RED.) REMOVE! The Laser section from An "OLD" WORKING, CD-Re-Writer, Be Careful, with Regards The: "HEAT-SINK" Un-Solder & "SET" Using, Epoxy Resin! (This will not Damage-Lens-Assembly!) You Will require, A "LENS" From: an existing: "LASER-POINTER. ( SIMPLE!)
I, personally Created: ( 500Mw. / RED / VERY-BRIGHT. / BURNING! @ 4v5 & 1N4001. / VERY-HOT! / USE: 2x1N4001. / Should, operate & 4v5 + 2xDIODES. ( LOVED-THAT-LASER!)
Stephen Michael Spencer (ESQ.)
Pippin1066
Post by Pippin1066 » Tue Oct 15, 2013 11:04 pm
Just search eBay for 'laser line module'.
Here is one : http://www.ebay.co.uk/itm/650nm-10mW-la ... 53e41f726a
Pippin
