MINERAL-115 wrote:Thanks for the reply, Relayer!
You're welcome.
MINERAL-115 wrote:I've not attempted to switch the unit back on since noticing the damage, but would it be worth wrapping the two pins that have came away in electrical tape (I've got some Super 88 handy), then putting those two in by hand with some tweezers? I'd then clean up the rest of the connector with a scalpel and just connect that part as usual.
That is probably the easiest way to do it.
MINERAL-115 wrote:I wouldn't even know where to start in an inspection and measurement of a damaged PCB, but at least then I could have the connection back in place to see if the TV is still able to operate.
No, I wouldn't try reconnecting and powering up the TV, as there's a good chance you'll blow other components.
MINERAL-115 wrote:...I can't even remember if it was PL801 or PL802 that caused the damage, as I was too concerned with disconnecting the power and the connector at the time. I'm hoping it was PL801 that did it, but I'm not entirely sure.
Due to you turning off the power to the telly ASAP, this may have saved other components down the line from being destroyed.
By this I mean, that some components take time for them to be damaged. While the TV was going at power up to when you switched off may have been just a second or two. In this short period of time, some parts will tolerate incorrect voltage or reversed voltage polarities. But in time it will exceed their tolerance and either go open circuit, short circuit or explode.
You really need to do a visual inspection, starting from the connectors that you accidentally reversed the plugs on. You need to follow each track to a component/s. Flip the board over and have a close look at the part/s. If the track ends to one side of the part and you've had a look at it, go to other track branches from the connectors. This can end up being time consuming and tedious, but at least when you're satisfied you've checked as best as possible, you can get a 10 foot broom stick and turn on the telly with it.
Please keep me posted.
Regards,
Relayer
