Bringing V and I in phase
hello
I have a problem with an inductive load (230/12 transformer) running via TRIAC BTB16600BW. The TRIAC is controlled via PIC MCU optically coupled with MOC3020. Even though the TRIAC is a 'snubberless' version from ST...i have still added a snubber network across the TRIAC anodes. The TRIAC is controlling the phase angle on the transformer HT (input side) and the transformer LT side is powering a 12V halogen lamp.
The above setup described is actually a PIC dimmer and works well if an electronic transformer is used instead....but i need to use simple transformer.
The problem happening is that with the SIMPLE transformer....it is heating up very quickly even though the rated VA of the transformer is powerful enough and my halogen lamp is only 25W. Of course this is happening due to the inductive load nature and V and I are not in phase. In order to bring the V & I in phase i connected accross a 100W/230V normal light bulb accross the transformer HT. This has fully solved the problem and now every thing is running smoothly with no over heating anywhere in the network circuit.
However having a 100W bulb ballast is not practically feasible for long term...So please can someone advice on a better alternative to correct the V and I phase out problem? I hav also tried power resistor to simulate the same 100W bulb ballast but it over heats! I hav also tried to remove the 'snubber' network, but that made no difference.
Im also enclosing my diagram web link for the actual circuit arrangement......
http://www.microchip.com/forums/photo_v ... e=0;425927
Please can someone help?
hhssmm
hhssmm
nigelwright7557
Re: Bringing V and I in phase
You need to offset the inductance with some capacitance.
Put a capacitor across the transformer.
www.murtonpikesystems.co.uk
