The digital display on my motorcycle recently failed. ( the display powers up and the back light comes on but none of the readings display)
After researching on a bike related forum the issue is due to corrosion on the circuit board which can be resolved by a clean up in lucky cases or a replacement of damaged components in bad cases
In my case the clean up did not work. I believe i have located the parts in question but not being an electronics expert i'm having trouble identifying them and working out what suitable replacements I need to buy.
From what I understand the parts are surface mount diodes.
I have inspected the parts with a magnifying glass and can see the following item number in the following format marked on the top of each item:
S
1G
72
I've searched online and can find anything that matches this part number. Unfortunately i'm not able to find out the manufacturer.
The guys on the bike forum have said that its a general purpose diode with around a 1 amp capability which does not need to be fast switching or high voltage. I've attached a pic below showing one of the components. ( the other one has already been removed)
Is anyone able to help me identify the part and advise me on some replacement or alternate parts that i can get hold of in the UK from somewhere like RS so i can try and repair the board?
I dont mind if its not the exact same part, just something that will do the job ( if that's possible)
