electro mechanical amusement machine relays
TONYM
Post by TONYM » Thu Apr 11, 2013 4:33 pm
Hello everybody,I am new to the forum and would be grateful for advice as I know very little on the subject. I am a private collector of vintage coin operated machines-the kind often seen at seaside resorts. Up until now they have all been mechanical but recently bought my first electro mechanical machine which is called Top Dog and made probably in the 1960s.It has a problem with at least one of the relays.The relay is enclosed in a clear plastic enclosure which is partially broken and has OMRON MH2 on it.Inside,on the coil it has 1250 ohms printed on it and on the metal part the number 062764 ,It has 8 terminals [does this mean it is DPDT?] and I have established it runs on 24volt dc. I've tried Farnell and RS electronics for a replacement but to no avail,perhaps as I can only make contact with an operator. I appreciate finding the same relay might be problematical but perhaps I could use an alternative? Thanks in advance,Tony.
Re: electro mechanical amusement machine relays
Post by piratepaul » Mon May 20, 2013 3:56 pm
I have not looked up the numbers but it sounds like 2 relays... 2 input terminal pairs and 2 out put terminal pairs giving 8 pins try a truck supplier or marine electronics suplier or the obvious fleabay. There are lots to chose from on a truck.
