MLCC SMD capacitor replacement
mark75
Post by mark75 » Sun Aug 10, 2014 1:28 am
Hi, I have a graphics card with 2 fried capacitors I would like to replace. I am brand new to electronics so I bought a multimeter and looked at some youtube vids. I would be extremely grateful for some guidance moving forward with this and I also have two questions about how to read the multimeter correctly.
I set the Ohm setting to 200 and the caps read 8.3 - what is the actual uF value of this reading please? I'm assuming 8.3uF.
The voltage of capacitors on the same row all read 1.2 when the multimeter was set to 20v - what is the actual voltage value of this reading please? I'm assuming 1.2v.
Many thanks in advance!
Mark
[Edit: Ohm setting from 2000 to 200 to give 8.3 instead of 020]
Re: MLCC SMD capacitor replacement
Post by piratepaul » Mon Aug 11, 2014 1:49 pm
The cap is not 8.3 uF... I am not sure how to do that real other than an LCR meter or some mind boggling sums.
The voltage is 1.2V.
Spikky
Post by Spikky » Fri Sep 05, 2014 12:21 pm
Post by piratepaul » Fri Sep 05, 2014 5:55 pm
If the reading is 1.2 when the meter is set on upto 20VDC the voltage between the electrode is 1.2VDC.
