Can you help me find two-pin (not four pin) Tactile Switches
Custom24
Post by Custom24 » Thu Jul 15, 2010 1:28 pm
Hi All
I have an old guitar effects pedal, the Zoom 8080, which I love.
However, some of the switches on the circuit board inside it need replacing.
I can't find anywhere that sells them in the UK (or anywhere at all for that matter) - any ideas? I live in Gloucestershire.
They are very similar to this, but they have only two pins, not four.
http://www.maplin.co.uk/Module.aspx?ModuleNo=4196
Thanks for any help
Mark
Re: Can you help me find two-pin (not four pin) Tactile Swit
Post by Simon (Webmaster) » Thu Jul 15, 2010 6:19 pm
Are the pins in a different position than on the 4 pin ones? I'm just wondering if you could cut off 2 of the pins (each side of the switch has 2 pins connected together) - I seem to remember doing this for something in the past. Failing that have you tried Farnell (www.farnell.com) or RS (www.rswww.com)? They have a big range, only problem is they both have minimum orde values unless you are an account holder.
Custom24
Post by Custom24 » Thu Jul 15, 2010 9:16 pm
Hi and thanks for the reply.
The pins are centred on opposite sides rather than on the corners, so I can't cut them off. I did buy some 4 pin ones before from Maplin to see if that would work, but alas, no.
Post by Simon (Webmaster) » Wed Jul 21, 2010 8:28 pm
I'll try to remember to have a look in the Farnell catalogue at work for a 2 pin version - probably easier than trying to find one on their web site.
