Newbie needs help with circuit
First of all - Hi all
Secondly
I do not know much about electronics and circuits. I know it's a bad way to start this post, but there's no hiding it.
Moreover that's exactly why I am here, because it seems to me, that what I have in mind is quite easy for a person that knows that s/he's doing.
OK so what I want to do is
1) have a switch (A)operating on the main 230V power line - like a light switch, but this switch would be one operated by another circuit of much smaller voltage - so when the low voltage circuit is closed by its switch (B) the high voltage circuit would be closed by the switch (A)
2) have a mean of transforming the 230V voltage into a much smaller voltage to power the low voltage circuit.
OK I hope I made it clear. Would you know how to do this? I would appreciate any help and would be very grateful for names of the particular parts I need to get.
Andrew
Secondly
Andrew
Re: Newbie needs help with circuit
something like this?
http://www.emosystems.co.uk/Products/Ma ... ystem.html
the master unit can be controlled by a slave using a low voltage line
or something much cheaper and simpler
http://www.maplin.co.uk/Module.aspx?Mod ... &U=strat15
obviously you could break into the transmitter and put your own switich across it
williamarren
This is another newbie..I am just planning to develop my own electronics lab at home..I am in great need of best suggestions that helps me in this regard...
Excuse me if i posted in wrong area..Move me to the correct thread.
Thank you
Thank you
top newb use a transformer isolated like a old helogen light 1 and relays of sed apropreate ratings trasformer gives low volts to power relays add switch gear to cct and contacts go to mains cct
bottom newb read some books dicksmith funway and jakar these are good beginers stuff and a few tools and muiltimeter and soldering iron are all u need to start if lost mm me
