Esd Matt help
Esd Matt help
Hi all I fix iPhones and a few screens are effected by static so I now have a esd mat which a metal popper that attaches to a wrist band but do I need to ground the mat to a power outlet earth? Or is it ok just to use the Matt with the wrist strap thanks
Re: Esd Matt help
You need to ground the mat to a power outlet earth via a 1M resistor. Best to use one of these.
Re: Esd Matt help
Ok cheers but I only have one popper on my Matt so that would go to the bonding plug but then we're my wrist strap plug into ? Also the boding plug ?
Re: Esd Matt help
Most mats I've seen have two bonding posts.
If you got the earth bonding plug as suggested and your mains outlet is near by you could connect your mat and wrist strap to that.
